07-28-2018 03:31 AM
スタンドアローンアプリケーションを作成するためにビルド仕様から操作をしたいのですがビルド仕様が表示されていません。さらに動画などではビルド仕様の他にもいくつかの項目があるようなのですが、source distributionしかありません。これを解決するにはどのようにすれば良いのか、御教授頂けたら幸いです。
I want to operate from the build specification to create a standalone application, but the build specification is not displayed. In addition, it seems that there are several items besides the build specification in movies etc., but there is only source distribution. I would appreciate hearing about how to solve this problem.
07-28-2018 06:25 AM
07-28-2018 08:17 PM
When I looked it turned out that there was no application builder license. Is it not possible to use it in the evaluation version? Also, if it can not be used, is it impossible to save the program to myRIO?
07-28-2018 10:29 PM
They were hoping to see a screenshot of the licenses, not the launching screen. But, it sounds like you answered the general question. The only other part that is missing: which LabVIEW Development System option has the green dot? Base/Full/Student/Pro? Pro is ideal for your question.
You get 7-45 days to evaluate the software after the first install. But, it doesn't sound like you're hoping to evaluate. You're hoping to use the functionality longterm.
You can run the myRIO in interactive mode. But, you cannot build a startup executable to push to the myRIO without Application Builder.
07-28-2018 11:27 PM
Thank you for quick response.
Is this OK?
07-29-2018 02:24 PM
07-29-2018 02:27 PM
It looks like your License is for the Professional Version of LabVIEW, which I believe includes the Application Builder. Try clicking the button next to Application Builder and see if you can "turn it on". You would probably need to reboot your machine ...
