02-28-2011 10:47 PM
シフトレジスタを使用して、ループ前の値と後での値を比較し、ある値以下になると終了したいのですが、ループ前の値をどのように保存すればよいかお教えください。
03-01-2011 01:24 AM
Google translate:
Using a shift register, comparing the values before and after the loop, I want to end below a certain value, please tell me face How do I save the value before the loop.
Simply wire the start value through or around the loop (if i misunderstood a .vi showing the issue can be helpful).
/Y
Google'd back:
単に介して、またはループの周りの開始値を式(Iを誤解している場合。役立つことが問題を示す六)。
03-01-2011 02:12 AM
thank you for your information.
the vi is curve fitting. I would like to end the calculation at the point of no difference of the five life times of a reaction. The vi is a little bit complex. So I hesitate to send it to you as the attachments.
03-01-2011 02:36 AM
I would like to senda part of the vi. The lowest shift-register hsould use the comparison between before and after.
I expext you may help me about it.
With my best wishes,
SunnyMyung
03-01-2011 03:44 AM
Do you want to stop calculating when the 5 doubles (are they the life times?) are equal in between loops?
I imagine 2 solutions, basically the same:
- build an array connected through a shift register, compare the new with the old array (the one coming from the shift register)
- Same thing, but with all wires compared separately. (using the existing shift registers)
/Y
