12-30-2006 02:34 PM
12-30-2006 02:51 PM
12-30-2006 05:25 PM
Thanks for replying.
I don't have a [current folder] and no [ cancel] I have looked all over the NXTToolkit folder and it's not their.
I'm thinking that I must have loaded the programs wrong, but I can communicate with the NXT brick over bluetooth.
I have none of the compile files?
hal2020
12-30-2006 05:38 PM - edited 12-30-2006 05:38 PM
@hal2020 wrote:
...I have looked all over the NXTToolkit folder and it's not their.
All you need is the NXTtoolkit folder.
Message Edited by altenbach on 12-30-2006 03:38 PM
12-30-2006 06:11 PM
Thanks again
I have opened labview and under tools I do not have a advanced or mass compile to click on.
so without being able to click on advanced I can't get to the screen you have shown me.
My NXTToolkit folder looks just like the one you have. but I can't get to it the way you did.
I am going by the instructions that follows.
Mass Compiling
To run this toolkit efficiently, you must mass compile the toolkit VIs in the version of LabVIEW in which
you installed the toolkit. Complete the following steps to mass compile the LabVIEW Toolkit for LEGO
®MINDSTORMS
® NXT.1.
Launch the version of LabVIEW in which you installed the toolkit.2.
Select Tools»Advanced»Mass Compile. __(((THIS IS WHAT I CAN'T FIND?????)))___Tools is their but no ADVANCED????3.
Browse to the labVIEW\vi.lib\addons\NXTToolkit folder and select Curr Dir.4.
Select Mass Compile to begin the mass compile process.Note
Mass compiling the toolkit takes around 10 minutes on most computers.Hope this helps you understand .
Thanks again
hal2020
12-30-2006 06:23 PM - edited 12-30-2006 06:23 PM
Maybe you should try to repair the LabVIEW installation, who knows what else is missing. :(. Did you originally install everything into its default location? Does LabVIEW work fine otherwise?
Here's my 7.1 menu for your reference:
Message Edited by altenbach on 12-30-2006 04:23 PM
12-30-2006 06:58 PM
I can't Thank you enough. For that last picture.
I was opening labview all the way to a new vi, but when i went to the first screen the last pic you shoued me I found ADVANCED.
And was able to compile.
meny thanks from an old man that some times suffers from Operator head space.
Thanks again
hal2020
12-30-2006 07:30 PM
09-19-2012
10:01 AM
- last edited on
06-16-2026
03:33 PM
by
Content Cleaner
I installed Labview 2011 (have license) on 😧 Dics and install Labview LEGO MINSTORM NXT module from website: http://www.ni.com/white-paper/4435/en (choice Download the toolkit, then register information to download) add-on Labview. Then install completely, I launch Labview and choice Tool -> advanced -> mass compile, I don't find Cirr Dir file. Can you help me? thank you so much. This is a attached picture.
09-19-2012 10:08 AM
Have a some mistake and I want to add more information. I install Labview from DVD and install full. I choice tool - advanced - mass compile, then 😧 LABVIEW/vi.lib/addons/NXT toolkit. as a result of the same picture which I posted.
