08-24-2008 09:41 AM
back in Jan 2007 there was the posting below - has this been fixed by any chance? I cannot find teh open VI in teh terminal window of pc either (using student 8.0 german version).
P
copy of posting text below:
@Brumma wrote:Hi Daindim,
I have the same problem with the German version of LabView 8.2. I can't see the VI in my NXT terminal. Is there a nother solution then install an old version?
Bruno
Hi Brumma,
If you have a non localized version of LV - means an english one - it should work.
Daindim
Solved! Go to Solution.
08-26-2008 03:13 PM
Ok - I did find the patch on the VI site - should have searched a bit longer !
Problem solved, the example code runs nicely.
Thanks to all VI developers who have made this possible.
P
12-11-2008 11:14 AM
I have the same problem with my german version of LV8.21 and the NXT-Toolkit.
Could you or anybody else show the link to the mentioned patch.
12-11-2008 01:59 PM
Sorry hher,
for the life of me I cannot remember the exact link. I have the patch down loaded on disk and the file contains a html readme: Here is
the extract describing its installation
Complete the following steps to install the LabVIEW Toolkit for LEGO® MINDSTORMS® NXT 1.0.1 Patch for Windows.
Try searching for this zip file? I must say I could not locate it tonight either on the ni site.
P
12-11-2008 02:06 PM
PS to hher - there is a message also from member 'engseeo' in this message board with the patch attached as file!
It is under message subject 'compile error'
Good luck!
P
12-12-2008 11:54 AM
Thank you.
The patch worked for me.
I saw this patch before, but thougt that it is only for some problems in LV8.5
