LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Lego NXT with Event Structure
Hello:
I am trying to do a remote laboratory with a LEGO NXT being controlled in direct mode by a computer running LABVIEW. The Users (students) can try their algoritm via internet. In case the robot gets stuck doing a task (for example, ""go foward") I was planning to do an event structure that activated with a buttop (Stop Button). The idea is that the user pushes this stop button, the event structure activates, and then the Lego NXT stops on its tracks an the VI stops.
I am having a problem is telling the NXT to stop. The NXT Labview blocks have a line connecting them indicating the program flow. I think the problem would be solved if I could get that instance of the program flow inside the event structure. Is this posible?
Thank you for your time.
(5,473 Views)
Just wire the NXT sequence wire from outside the structure to the stop block inside the structure. It should create a tunnel on the structure frame automatically.
Also, the NXT Pink wire isn't strictly required, it is only there for sequencing when convenient.
(5,459 Views)
