LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Lego Mindstorms 1.0 crashes on Startup
I cannot open Lego Mindstorms NXT 1.0 without it crashing. I have re-installed but it continually crashes on startup.
Crash details below. Please help.
Process: MINDSTORMS NXT 342
Path: /Applications/LEGO MINDSTORMS NXT/MINDSTORMS NXT.app/Contents/MacOS/MINDSTORMS NXT
Identifier: com.ni.labview
Version: 1.0 (1.0)
Code Type: PPC (Translated)
Parent Process: launchd 189
Date/Time: 2011-01-09 14:43:22.913 -0800
OS Version: Mac OS X 10.6.5 (10H574)
Report Version: 6
Interval Since Last Report: 14936 sec
Crashes Since Last Report: 2
Per-App Interval Since Last Report: 81 sec
Per-App Crashes Since Last Report: 2
Anonymous UUID: 16718684-B78B-4657-AB41-8127BABE0682
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 com.ni.labview 0xb80c0057 0xb8000000 + 786519
1 com.ni.labview 0xb80dd8e8 0xb8000000 + 907496
2 com.ni.labview 0xb8145c1d spin_lock_wrapper + 3973
3 com.ni.labview 0xb801ceb7 0xb8000000 + 118455
Model: MacBookPro3,1, BootROM MBP31.0070.B07, 2 processors, Intel Core 2 Duo, 2.6 GHz, 2 GB, SMC 1.16f11
Graphics: NVIDIA GeForce 8600M GT, GeForce 8600M GT, PCIe, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x87), Atheros 5416: 2.1.14.5
Bluetooth: Version 2.3.8f7, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
PCI Card: pci168c,24, sppci_othernetwork, PCI Slot 5
Serial ATA Device: FUJITSU MHW2160BHPL, 149.05 GB
Parallel ATA Device: HL-DT-ST DVDRW GSA-S10N, 357.1 MB
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8502, 0xfd400000
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x021a, 0x5d200000
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x5d100000
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8205, 0x1a100000
(8,025 Views)
Hi nmz027,
Could you tell me if you are using NXT for LabVIEW or NXT G?  Also, have you recently installed this software and it has been crashing ever since or did the software just start crashing?  If it started crashing after working fine previously, could you tell me if anything had changed, if power had been lost, etc.?
Lynn
Senior Systems Engineer
(8,018 Views)
I am using NXT. It used to work but I have not openned it in a couple years. So I wouldn't know when it stopped.
(8,015 Views)
Hey nmz027,
You may want to try this procedure:
Apple Forum - EXC_BAD_ACCESS (SIGBUS)
They attempt to run NXT again to see if it still crashes.
Lynn
(8,010 Views)
