05-21-2008 07:46 PM
05-22-2008 08:42 AM
06-16-2008 06:09 PM
06-17-2008 10:30 AM
06-18-2008 08:44 AM
Are you trying to connect with USB or with Bluetooth?
@Onnimikki wrote:
I have just installed Labview 8.0 on Mac OS X 10.5.3 (Leopard). The computer is a Macbook Pro (Intel). I downloaded the LabVIEW Toolkit for MacOS from https://lumen.ni.com/nicif/us/evallegotoolkit/content.xhtml. When I try to connect to the NXT device using the "Terminal" within Labview, Labview freezes and crashes. This has happened three times now. Is there a fix for this problem?
Thank you,
James
06-18-2008 08:45 AM
I'd suggest trying to use the file primitives (open, write) instead of the write to spreadsheet file.
@rvcb wrote:Hi,I am user of the program LabView Student Edition 7.1.1 and I am using it in the extent of my dissertation to program a robot Lego Mindstorms NXT (Firmware V 1.05). My intention is to collect data with the robot through rotation sensors of the lego. When I transfer the program for the robot an error message appears saying that it cannot open the VI because it is protected by password (see image in http://fisicaequimicaa.com.sapo.pt/mensagem%20de%20erro.jpg). This message only began to appear when I introduced into the program the code to export the data collected to a ficheiro that can be opened in Excel. Before, when in the program just had the sensor and the graph this mistake didn't appear and the program worked well. The program that I use has the addons made available on NI page to work with the robots NXT and with Robolab.I would appreciate your help to solve this problem. If there is a problem in the code I would appreciate your help in with clues on how to solvew it.
Thankyou and Best Regards
06-18-2008 09:54 AM
06-20-2008 08:33 AM
@Onnimikki wrote:
I'm using USB.
06-23-2008 02:52 AM
@JS wrote:
@Onnimikki wrote:
I'm using USB.
We looked here and we've never seen that before. We'll try and duplicate it and see if we can make it happen here. In the meantime, can you look in your Apple System Profiler in the software area under frameworks and look at the version information for "fantom"?
06-26-2008 03:45 PM
I think we've duplicated it here and we're trying to figure out what's going wrong. Stay tuned.
@Onnimikki wrote:
Here's what it says:
Fantom:
Version: f0
Last Modified: 17/06/08 4:36 PM
Get Info String: LEGO MINDSTORMS NXT Driver 1.1.1f0, Copyright (c) 2003-2007 National Instruments Corporation. All Rights Reserved.
Private: No
