LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
LabVIEW Crashes on 2 Different PCs using Datalogging vi that Worked Fine Last Week!
I'm a little confused. Are you seeing the crash in your current version of NXT Module or after you updated to f3? Earlier you said that you updated and then started seeing this behavior, but your screenshot shows that you're not running the f3 patch.
Message 11 of 12
(2,938 Views)
Sorry, let me clarify.  "Worked fine last week" in my post title meant that it worked fine before f3 patch.  Then it started crashing after I allowed the patch to install (apparently my updater was a few months behind since it only pushed that patch last week -- ?).  When crashing began, I uninstalled the f3 patch.  The current version you see that I have is with f3 uninstalled, and it no longer crashes with datalogging.  So, I'm fairly certain that if I accept the f3 patch again that it will kill my datalogging functionality again.  And that's why I'm asking if there are known issues with f3.  Make sense?
Message 12 of 12
(2,937 Views)
