LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
LEGO EV3 and OPC Server
Hi all! How could I connect EV3 brick to OPC Server? Is it possible to send variables from sensors to OPC and control via SCADA?
Message 1 of 8
(7,985 Views)
I believe the Lego EV3 should be controled by LabVIEW using the NI LabVIEW Module for LEGO® MINDSTORMS®
As LabVIEW can also connect to any PLC using OPC server, you will then be able to exchange the data between your PLCs (or your SCADA) and your LEGO, as long as the LabVIEW application is running.
>> Connect LabVIEW to Any PLC Using OPC
>> Connecting to the LabVIEW OPC Server from Third-Party OPC Clients
Have a nice day,
M-Junior
Message 2 of 8
(7,945 Views)
Thanks for links, but I've already read it. There is a problem with Labview: when i try to connect to EV3 brick, i press "Scan" button, LabView find my brick then i press "Connect" and nothing happens. No errors, just Brick's status "Unavailable". No matter of type of connection (WiFi, Bluetooth or USB connection).
Message 3 of 8
(7,937 Views)
You do realize that this is a complete different issue than the one you open this forum for?
It is important for the other users that may find you forum thread helpful, that you post your messages in a forum related to a subject. If your issue is that you cannot connect your Lego to LabVIEW, you should open a new forum for that.
M-Junior
Message 4 of 8
(7,926 Views)
This forum thread is LabView for LEGO Mindstorms. I have problem with LabView and LEGO
Message 5 of 8
(7,920 Views)
This was your question : "Hi all! How could I connect EV3 brick to OPC Server? Is it possible to send variables from sensors to OPC and control via SCADA?"
Message 6 of 8
(7,918 Views)
Yes, it was. And I have problem with connection. I don't have experience in LabView, and if i posted in wrong thread, i'm sorry, but could you tell me where should i ask for help?
Message 7 of 8
(7,915 Views)
Please re-create a new message in the LabVIEW for Lego MINDSTORMS forum thread but this time explain that you are having troubles connecting your mindstorm to LabVIEW. Explain what steps you have taken, and where you fail to succeed. This way you shall have much more answers.
have a nice day
M-junior
Message 8 of 8
(7,913 Views)
