LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Import Dll to labview
Hi Dominic
Many thanks for your quation if I need help.
Have you managed to sort out the data type conflict you were seeing? No
Do you need further assistance? Yes(becouse the funtion inside the dll boolen type and this not avarable in Labview also I need this type  from check if my motor responde or not) I don't now how warp this problem).
Best Regrads
Message 11 of 13
(3,157 Views)
For a boolean use an I32 (signed 32bit integer).
0 == false
1 == true
Ref: http://forums.ni.com/t5/LabVIEW/if-a-variable-is-bool-how-to-specify-it-in-call-library-function/td-...
Chris
Certified LabVIEW Architect
Certified TestStand Architect
Message 12 of 13
(3,152 Views)
Hi
i will try to use now
Message 13 of 13
(3,148 Views)
