LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Help finding examples of simple signal processing - regressions, etc
Hello All,
I was wondering if anyone has any examples of simple signal processing using the NXT (Labview 7.1 student edition with NXT plugin is what we're using).
This would be for example, reading the distance from a wall with the ultrasonic sensor to see what angle your approaching at, so you can steer based on the result.
Another example would be for passing by an object, reading the high/low point in the signal to determine the center (so you can pick it up).
I'm assuming that the only functions you can use with the NXT are the ones in the NXT subdirectory on the functions palette?
Thanks for any help you can offer.
Message 1 of 1
(5,769 Views)
