LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Broken Mindstorms NXT 2.0 Installation
I have tried to install the old Mindstorms NXT 2.0 Software on a WIN10 PC to let a student play a little.
Yet I have failed Smiley Surprised
First I tried  to install the current version from https://www.lego.com/de-de/mindstorms/downloads/nxt-software-download (2.0f6)
When starting the software, a broken VI (in fact the Splash Screen) is reported.
Trying to re-install as suggested by the error message did not help. In fact removing the driver took three attempts until it had disappeared from the list of installed programs.
Next step was installing the original version which came on CD with the robot (after finally having found an optical drive Smiley Wink)
The result was more or less the same. Only the error message was less sophisticated.
To me it seems there is a problem with the driver. Anybody seen similar behavior and know how to fix it?
Cheers
Oli
(6,562 Views)
Sometimes... one should have a cup of coffee before posting....
The application is working, but only if started with Local Admin Rights! Smiley Surprised
Any way around? Otherwise I will have tough negotiations with corporate IT....
(6,559 Views)
