LabVIEW at UTM
Reply
Homework 2
Heard that many of you said homework 2 is hard, however there are some students already submit it and get it almost correct!
So please share your problem faced, we will discuss on it!
Message 1 of 14
(5,379 Views)
Re: Homework 2
I didnt know hw to do the connection in the block diagram  for the 1st part
all of them have different data type !!! so how ?
Message 2 of 14
(2,537 Views)
Re: Homework 2
Try to use the array function=> Index Array to perform the function.
Then you will know how to connect them together.
All the best!
Message 3 of 14
(2,537 Views)
Re: Homework 2
Actually this homework 2 is very difficult to do. i attended todays class but still find it difficult to do the homework please any assistant or clues?
Message 4 of 14
(2,537 Views)
Re: Homework 2
which problems that you found is difficult?
Message 5 of 14
(2,537 Views)
Re: Homework 2
i have solve all the problem except part 3.i dont know how to represent the rainbow colours with number by using string control n number indicator.
i  only know using enum can solve it. help me pls.
Message 6 of 14
(2,537 Views)
Highlighted
Re: Homework 2
For Problem 3,
You can use "Search 1D array" function and an array constant.
Try to initialize your array constant with the rainbow color.
All the best!
"We will can it, and finally we will make it!!"
Message 7 of 14
(2,537 Views)
Re: Homework 2
lol... search 1D array???
i use "match first string" function... also can...
Message 8 of 14
(2,537 Views)
Re: Homework 2
thank you very much
Message 9 of 14
(2,537 Views)
Re: Homework 2
Ya, it is also correct. However, we prefer you to use search 1D array..
Because we want you to familiarize with Array Function first.
Message 10 of 14
(2,537 Views)
Reply
