10-26-2012 10:33 AM
I'm still evaluating LabVIEW Web UI and I've not yet built/deployed any application.
But is it possible to deploy my Web UI applications to the NI cloud storage, using it as the host?
Besides, is it required to have LabVIEW installed on the application host?
Finally, is it required for the client to be on the same network of the host application?
Marcelo
10-30-2012 07:18 AM
Hi gracietti,
your answers:
No, it isn't. To build or deploy your application you must have a labVIEW Web UI Builder Development license.
It is necessary to install the Microsoft Silverlight browser plug-in to view and access LabVIEW Web UI Builder
No, it isn't. You can access the application from another network, but you need to use port forwarding. More informations: http://digital.ni.com/public.nsf/allkb/FE64994F19D12273862579AB008001D1?OpenDocument
I hope this help us.
11-25-2012 10:36 AM
I think we may have some confusion about the term "host" here.
It is the client (computer viewing the WebUI thin client) that must have Microsoft Silverlight installed (and that's it, no LabVIEW == power of web services).
The host, the computer whose web address you go to to view the web page, must have the NI Application Web Server installed to host the WebUI Builder output file.
host = NI Application Web Server (included with LabVIEW or available for install through a LabVIEW-built installer)
client = Microsoft Silverlight plugin (available freely from Microsoft)
