LabVIEW Web UI Builder and Data Dashboard
Data Dashboard Showing "no supported variable..."
Hey egupta,
You didnt give to much information to go on with this post.  Where are you trying to change the data type?  For the shared variable or for the Data Dashbard indicator?  As Adam mentioned (with a link to this KB), that data type is supported for use in Data Dashboard  with shared variables and therefor you should be able to connect it to a graph in Data Dashboard.
KiraT
Message 21 of 23
(5,119 Views)
Sorry for the inconvenience
I am providing details:
I am trying to work with Data Dashboard 1.0 for android.
I am receiving data from cdaq 9191 chassis and want to put it into a shared variable which I would deploy and then receive in the android smartphone.
However the data I am receiving from the chassis is of the form of a graph(it says the data type is a "cluster of 3 elements").
The smartphone can only support scaler data type like double, integer etc. so I am unable to proceed.
So, I wanted to know if I could change the graph data type into something the phone would recognize.
I want to do it in the LabVIEW program itself.
I am attatching a screenshot of the program.
Message 22 of 23
(5,113 Views)
This looks like it is the same question that you are asking here.
I will answer on the other forum since this is more of a LabVIEW question than a Data Dashboard question
Message 23 of 23
(5,097 Views)
