LabVIEW Time Sensitive Networking (TSN)
Reply
Re: Deterministic Communication - TSN API Example
Hello Burt_S,
I can't seem to find any other community examples in the TSN Community Examples directory except the TSN Simple Talk - Listen example after installing the TSN Community Tools Base Package and TSN Monitor Tools .vip packages. Were they removed recently?
Thank you!
Message 21 of 27
(272 Views)
Hi DevinToh
The Simple Talk - Listen example will show you fundamentals of setting a stream between two devices. In addition, you can look at TSN driver shipping examples in the C:/Program Files/National Instruments/LabVIEW <version>/examples/tsndriver. They pretty much demonstrate the same thing.
If you continue to install other examples from the community they will be automatically added to the TSN Community Example directory.
Message 22 of 27
(255 Views)
Hello Miro_T,
Thank you very much for your reply.
I have looked at the directory you have specified but I did not find any examples for the TSN API. Searching in the NI Example Finder did not return with anything as well. I have the necessary TSN drivers installed and can access the NI-TSN API 2017 palette. Do you have any examples for the new palette that I can reference to? All the community examples that I have so far is still using the old TSN palette.
Thank you so much!
Devin Toh
Message 23 of 27
(249 Views)
Did you install the VIPM on this location?
https://forums.ni.com/t5/LabVIEW-Time-Sensitive/Community-Tools-TSN-Monitor/gpm-p/3648042
I found you can't search in examples but you can browse for them using the Directory Structure:Example Finder.jpg
Here is what your location on disk should look like:
Message 24 of 27
(243 Views)
Hello Hokie,
Thank you very much for replying.
Yes, I do have the TSN Community Example that came with the TSN Monitor vipm file. I was actually referring if there are any examples that is provided by National Instruments that utilizes the new TSN 17.0 API Palette (Create Talker/Listener, Commit, Start, Write/Read, Stop, Destroy).
I have noticed that in the community example, community APIs are used instead of the Create Talker/Listener API in the TSN 17.0 palette to configure the TSN communication:
Is it possible to use the Create Talker/Listener API with the stream property node to configure the network?
If so, how do I configure the values in the stream property node? Do I still require the CNC software to generate these values with the new TSN 17.0 palette?
Thank you very much for your help!
Devin Toh
Message 25 of 27
(235 Views)
Hi Devin,
You can just configure the connection with a property node as you've done. The shipping example that comes with TSN 17.0 is a good example of configuration using property nodes, and comes preloaded with default values. You can find the example at the following file path:
<LabVIEW Directory>\examples\tsndriver
You should see a project which has two targets configured to be either talkers or listeners.
Austin
Product Support Engineer
Message 26 of 27
(208 Views)
Hello Austin,
I can't seem to find a shipping example in that directory. The only example that I have on TSN is the community example which I downloaded from this open group. Could you send me the project file of the shipping example?
Thank you!
Devin Toh
Message 27 of 27
(203 Views)
Reply
