LabVIEW Time Sensitive Networking (TSN)
Reply
Highlighted
Analog Input Acquisition with TSN cDAQs Example
Example demonstrates how to setup a DAQmx task for a synchronous analog input acquisition on two TSN cDAQ chassis. Example includes an optional phase calculation code which measure phase offset between two acquired signals and graphs their waveforms on the front panel. When two TSN cDAQ chassis are synchronized expected max phase offset between signals should be less than 1us.
This example is setup to be run on a host PC but can be also run from a cRIO - 9035/9 (Sync) or IC-317x controllers.
General Instruction Installing a VI Package (.vip) Example:
Download the attached .vip package to your PC. Double click on the .vip package which should open up a VI Package Manager (VIPM). In the VIPM window click on the "Install" button on the top left corner and wait for the installation to finish. Once the installation is finished, the example can be accessed from the LabVIEW example finder. In any LabVIEW windows click on Help>>Find Examples...>> Select 'Directory Structure' radio button>> scroll down and find TSN Community Examples directory.
Alternatively, example source code will be placed in C:\<Program Files>\National Instruments\LabVIEW 2017\examples\TSN Community Examples directory.
Message 1 of 1
(1,778 Views)
Reply
