Author: Aristos Queue (NI)
Right-click on a field of a private data control of a class and select "Find All Uses..." to discover all the places where the field is bundled or unbundled. This plug-in will find
The tool works for dotted fields inside nested clusters.
Before:
After:
It would be nice if we could export the list of VIs added to this
For the unnamed (un)bundler you could check if the element is wired?
"Give them a finger, and they’ll take the whole hand" 😊
EDIT: It depends a bit on what you want to know. If you want to know if it's save to delete the item, the unnamed (un)bundlers are relevant. If you want to know where the value is used or set, the element has to be wired.
EDIT 2: I guess it would be useful to have a "Find all reads" and "Find all writes" as well?
The items are labeled in the dialog, so skip the ones that aren't of interest to you.
Rev 2.
I still like this one a lot.
+1 for adding it at installation.
Could the menu be added to the (named) (un)bundlers of class data in a diagram*? As it is it's very useful, but I'm often in the diagram when I want to know if\where the item is also used elsewhere. I now have to locate the class's private data first.
* I know it can, technically, but are there reasons not to do it?
That's a good idea. I might have time in the not too distant future to return to this project. I'll consider it.
Hey,
Is there any limitation on the VIs to run this plugin on LV2017?
Felipe, I have saved it back to LV18, and it worked without problems.
I did save it back to LV16 for you, only to find I can't attach anything here...
BTW. In the spirit of 'always one more bug'...
There does seem to be a problem with clusters as private data. (Glad I don't have too many of them.)
It seems that access to individual cluster elements are not found.
GOOD: A 'find all uses' on a cluster or it's element returns access to the cluster.
BAD: A 'find all uses' on cluster or it's element does not return access to an individual element.
Thank you Wiebe. Don't bother. I am going to test here using a LV2020 install to save it back. I will let you know.
Apparently this post format is different. I haven't seen a place to attach either, nor reply.
The inability to attach is deliberate. These plug in directly into an editor. I do not want malicious persons uploading "improved versions" of plugins. People should always vet code uploaded to the Internet before running it on their machines, but these are particularly a threat vector, so I created a forum with the properties set that only allow the original post to host attachments. I also lock edits to only the original author.
Thanks for the bug report. I'd like to get time to work on this, but it hasn't happened lately. 🙂
It works in LV2017SP1.
Where do I install this llb in LabVIEW 2021 so all users can access?
I had this instruction in here
If you want a plug-in to only appear for a specific version of LabVIEW, you can add it to
or actually : C:\Program Files (x86)\National Instruments\LabVIEW 2021\resource\plugins\PopupMenus\edit time panel and diagram
but it did not work for my LabVIEW 32bit version.
I guess somehow I expected this feature to end up in LabVIEW automatically.
Here's an idea to add it:
For the record, another (tiny corner case) bug...
If the private data item ends with a space (which it probably never should), the (un)bundles aren't found at all.
Apparently, LV does us a favor by removing the space, so the name strings don't match.
Sure was nasty to figure out what was happening, or rather not happening. I hope the fix is just to use a reg.ex. instead of an equal...
