LabVIEW Shortcut Menu Plug-Ins
Grow to n.llb
Author: jtagg (NI)
Description
This shortcut menu plugin allows the expansion of (multiple) growable nodes to a specific size using a dialog box.
It can be applied to the following nodes:
  • bundle-type nodes (build array, merge errors...)
  • unbundle-type nodes (decimate array...)
  • index array
If several nodes are selected, it applies the same number of elements to all of them.
Screenshot
Attachement is saved in LabVIEW 2015. For install instructions, go here.
edit 12.12.2016: removed compiled code.
Comments
AristosQueue (NI)
NI Employee (retired)
on
Why did you put your plug-in after the Properties menu? That is very bad style -- Properties should stay the last item in a popup menu for anything that you're sharing out to the community. Please change your "After" back to "Before" in your builder VI.
jtagg
Active Participant
Active Participant
on
No real reason. That happened while playing around with the options and I never set it back. I've moved it back into its normal position. Thanks for pointing that out.
Craig_
Active Participant
Active Participant
on
Can you change the menu name to "Grow to n..."
The elipses indicate that the option will open up a window.
Craig H. | CLA CTA CLED | Applications Engineer | NI
jtagg
Active Participant
Active Participant
on
Done. Changed the text to "Grow to N Elements..." to make it a little more descriptive while still filling approximately the same width as the rest of the standard menu.
AristosQueue (NI)
on
Looks good. Thanks for making the tweaks.
Contributors
