The attached zip file contains all of my favorite shortcut menu plug-ins available for download on this community group. Note that my favorites are slightly different than AristosQueue's favorites. If your programming style and preferences are similar to mine, you may find it easier to install these plug-ins from my zip file instead of downloading them all individually. Here are the plug-ins contained in the attached zip file:
Grow to n
Insert Node on Selected Wires
Multi-select Change Local Direction
Set Current Event to Value Change
Show All Hidden Cluster Elements
Installation Instructions
1. Copy the contents of this zip file to your [LabVIEW Data]\PopupMenus\edit time panel and diagram folder. You may need to create this folder if this is the first time you're installing shortcut menu plug-ins.
2. Restart LabVIEW or run this VI to refresh your menus: LabVIEW 20xx\resource\plugins\PopupMenus\support\Refresh Menus.vi
Hi Darren, sounds like "Create Scalar Constant" is not included in your zip file!
Also, "Multi-select Change Local Direction" is missing in zip file.
Thanks, huangjinghit. I have updated the zip file to contain all 19 plugins currently listed as of 2015-12-17.
hi, Darren. I find the original code is written in LV 2015. Can you upload an earlier version? I use LV 2012 in my Mac Pro.
Also, I didn't even find LabVIEW 20xx\resource\plugins\PopupMenus path in my computer. After some serach, I find a new path which seems to store the menus VIs: /Applications/National Instruments/LabVIEW 2012/resource/dialog/PreferencesDialog/PreferencePages/MenuShortcuts_SubVIs. Is that right?
The shortcut menu plug-in feature is only available in LabVIEW 2015 and later.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
