LabVIEW Real-Time Idea Exchange
smithd
Simulate cRIO chassis for development away from the chassis
Right now, you can simulate the I/O from an FPGA target. Timing features and other hardware-specific VIs are not executed, but the code still functions and allows you to debug certain aspects of it without working through the compile process. It would be similarly helpful if you could simulate the real-time controller, or a cRIO in scan mode, with simulated IO. Again, the resultant VI will not be truly realtime, but it would allow useful development without having constant access to the cRIO.
22 Comments
nwxan90
I do not quite understand you are you looking to simulate the RT and the FPGA? If so i don't think it's possible to simulate the FPGA inside the RTOS VM.
CLA CPI
zundap1970
Sorry if i was not clear but seem have resolved the issue not using "found device" but via option "create" .
