On all of the RT platforms, if the CPU maxes out at 100% the RTOS goes through a sort of "load shedding" and begins suspending non critical threads to lower the CPU overhead and hopefully maintain determinism. One of the first threads that gets suspended is the TCP thread which essentially cuts off the RT target from the ethernet and outside world.
While I understand the concept of the load shedding, I believe that if you have the CPU pushed that hard, then your determinism is out the window anyway. Dropping the TCP thread only serves to disconnect the RT system from the development environment or the built application with no real benefit. I have yet to see a single application that was actually able to accomplish anything substantial after the point that the TCP thread was suspended. In most cases, the high CPU usage happens during the development of the application or when something is critically wrong with the setup of the deployed app. In those cases, it wouldn't matter how many threads you suspended, the CPU will still be maxed out.
It is akin to blowing out a match in the midst of a forrest fire.
I would propose that the RTOS be reconfigured to show the TCP thread as one of the critical threads and keep it from being suspended during high CPU excursions OR give the developer the option to turn this feature on or off throgh the device properties.
