It would be nice to add a filename Check in the Crio executable process generation, in order to detect accentuated characters !
When you use accentuated file names, the generated Crio Linux executable does not work ... it crashes without any message !!! => NI Linux does not support accentuated file names !!!
=> The problem is that the Debug mode works fine, and doesn't work like the executable !
It should be nice to add a file name verification to the generation processus in order to highlight the problem .
Thank for your help.
Manu.
