LabVIEW Real-Time Idea Exchange
Allow non default map constants on Real-Time targets
Status: New
Currently, non default map constants (like the one shown below) are detected as fatal insanities when deploying to Real-Time targets and crash the LabVIEW development environment.
There is a workaround, which is to build the map from other data structure constants. The map constant above was built from the code below. However, it takes longer to execute, and it takes more code. That is okay in some cases, but it would be better if there was an option to simply use the map constant above.
2 Comments
TomOrr0W
This sounds like a bug report rather than a feature request.  You might want to do a service request or at least post in the regular forums rather than the idea exchange.
User002
Not applicable
We have an open service request, and the Technical Support Engineer recommended that I also post the issue here.
