LabVIEW Public Beta Program in 2024
Preview Feature in LabVIEW 2024 Q1: Developing a LabVIEW Project in an Older Save Version File Format
Well, there are so many things to consider.... and corner cases... it might be a little too much to expect a mature solution for the first time.
Yet I expect NI to seriously work on this and digest the feedback the users are giving!
Message 71 of 73
(571 Views)
@Mads wrote:
Uisng this feature in 2024Q3 we have the issue that if we want to keep the project in a previous version (2022 in this case), but build the application in 2024 for testing purposes, it takes forever to do the build. I have yet to finish it as it just gets stuck for hours. If I change the version of the project to 2024 and re-run the build, everything runs at a normal pace and finishes as it should (still slower than it used to in 2022 e.g., but OK).
I have not seen a Bug filed for this issue. Is there any chance you could share code with me that demonstrates the problem?
Message 72 of 73
(562 Views)
No bug reported yet no. I am trying to establish if it has already been observed by others and whether it qualifies as a bug first.
This happens with several projects and I cannot share the code, but if it is an unknown issue I will try to recreate it in a shareable form later.
Message 73 of 73
(538 Views)
