LabVIEW Project Providers
Toolbar Button With Dropdown Menu?
Is it possible to create a GProvider with a drop-down menu from the toolbar button?
Like "Filter Project View", shown below?
You'll notice also the secondary project provider on my toolbar from the examples -- I was trying to modify it to have two sub-menu items below one button, but it's always showing three toolbar btns.
thank ya!
Message 1 of 10
(1,884 Views)
AFAIK no, it's not possible.  I haven't really tried but I would bet that Sumedha has at least looked into it.
Sumedha - Any ideas if this is possible?
I can do some testing and ask around over here, but I can't gauruntee anything from me until post-NIWeek if that is acceptable.  Things are getting crazy around here.
Message 2 of 10
(1,828 Views)
Thanks, David, we can defer this til after NIWeek.
Message 3 of 10
(1,828 Views)
Hi Jack, David
I don't know of a way to do this. But I am looking into it. So far all the ways I have tried are giving me the same result as Jack got. I will do more research tomorrow and let you know if I find a way to achieve this.
-Sumedha
Sumedha Ganjoo | LabVIEW R&D
Message 4 of 10
(1,828 Views)
It worked!
Here is the snapshot of Global_Init.vi that enabled this. Notice that the menu names have two levels ofhierarchy, i.e. two backslashes in their name.
Message 5 of 10
(1,828 Views)
Sumedha wrote:
It worked!
Whaaaaat? Too cool! Thank you, Sumedha.
Message 6 of 10
(1,828 Views)
Good work Sumedha, I'm glad you were able to prove me wrong 🙂
Message 7 of 10
(1,828 Views)
Smooth, I was looking exactly for this.
But I'm failing on creating a mixup of buttons and a "dropdown button" within one project provider.
Is there a solution for that requirement other than using 2 project providers?
Best, Jens
Kudos are welcome...
Message 8 of 10
(1,687 Views)
After lots of trial an error I finally got it working...
Use naming like "menu1/menu2" for all Buttons and then "menu1/menu3/select_x" for a pulldown-button for the "Menu Name".
Jens
Message 9 of 10
(1,656 Views)
Where can I find the code for this?
Keith
Message 10 of 10
(908 Views)
