01-24-2012 05:31 AM
I am trying to reuse the same menu item (LVOOP Assistant) for (at the moment) two seperate Provider plugins (Create Child Class, Rename LVOOP Labels) - i.e. each have their own ini file etc..
However, it creates two seperate entries for LVOOP Assistant.
Is there a way to fix this? - I experiemented with weight but that didn't help.
If not I am guessing I may have to just release everything in the one provider.
Cheers
-JG
01-25-2012 12:15 PM
I know of no way to do this in separate providers. I think you're best bet will to have them all as one provider 😞
If you want to get really creative, you could probably have one "Main" provider that populates the menu with data stored globally. Then each of the sub-providers can register their menu entries in the global data space. However this seems like it could get hairy and might not be worth the effort...
01-25-2012 08:46 PM
[effort] I concur - as long as you are happy signing another file
Thx for the reply.
01-26-2012 08:05 AM
Don't mind at all, send it my way...
