09-20-2017 09:13 PM
I had a license ID for the ini signer, and it had been actived in a computuer.
now i have a new computuer, and i want to use the ini signer for the provider development, but i can not be activation.
what can i do?
Is somebody knows how to do next? Tkx.
09-21-2017 04:35 PM
Are you using the latest INI File Signer Tool?
09-21-2017 07:24 PM
The INI File Signer in my computer was download two years ago. And i copy it to the new computer, then i submit the personal information and get a new activationfile.reg, is this cuase the license id invalid?
09-21-2017 07:30 PM
I used the tools download from the new URL you gived, and now noted this information.
09-22-2017 03:11 PM
Looks like that error only appears if the response, from the call to the signing cmd, is empty. Are you running LabVIEW with administrator privileges? Is the VI generating any errors in the Error Out?
09-22-2017 03:34 PM
The INI signing process has been posted publicly in an unofficial way. I'm not saying you should go through this process to sign your own INI, but if you are having issues with NI's signing method this might work the same for you.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
09-26-2017 12:21 AM
