LabVIEW Interface for Arduino Discussions
can not upload the fireware of the lavbiew interface to arduino
Another solution is to open up the block diagram of the Arduino Analog Read example and add a constant to the VISA resource input of the Arduino Init which specifies which COM port the Arduino is connected to.  Take a lo look at the following image to see what that would look like:
Kevin Fort
Principal Software Engineer
NI
Message 11 of 15
(1,032 Views)
Hi JH,
I tried Solution 1 :
Changed the name "Arduino" to "Communications Port", and ran that block... I don't really know what this is for, but the Panel showed two checkmarks where there was once one:
...but I had to changed that "Visa Resource" to USB each time I ran it - seems it's not the default... this is what the panel looks like if I don't change to :USB"
So I gather I need to, as Kevin_F suggests, add a constant to ensure that the correct port is selected when trying to run the Arduino Analog Read Pin.vi... I will try this next, but I think I might be in a little deep here - Labview in it's structure is so different from HMI's found in the Industrial setting, I really have no frame of reference. In those HMI's, there is always some sort of IO database configuration, and a place to setup drivers (sometimes in the same database). I will keep trying because I think I am close.
Message 12 of 15
(1,032 Views)
Christmas miracle guys!!!
What I did (without knowing what I was doing) was to copy and paste that VISA resource pulldown box you see in the bottom left, from the Auto Detect vi, to the analog read vi. I gather anything OUTSIDE of the box is initialization or exit code... so this allows me to configure the IO before I hit the play button... still haven't figured out how to just make this a constant, but at least I can play now!
Message 13 of 15
(1,032 Views)
Let us be generous - PFA for BYTE replaced
Message 14 of 15
(1,032 Views)
Just today I received my first Arduino and immediately ran into this problem, and its resolution described here. Thanks to all, this seems to be a very helpful community!
I had also the apparent problem that the Arduino wasn't detected; playing with NI-VISA-Configuration helped me to identify the correct ressource. I add a screenshot with all relevant settings, hopefully this helps better than 1000 words.
Happy New Year to all!
Message 15 of 15
(1,032 Views)
