From Saturday, Nov 23rd 7:00 PM CST - Sunday, Nov 24th 7:45 AM CST, ni.com will undergo system upgrades that may result in temporary service interruption.
LabVIEW Interface for Arduino Discussions
Readings not correct with 3 analog inputs using lifa
Hello ,
  I am having a trouble with multiple analog inputs through my  Arduino on labview interface.  It seems like the signals are leaking into eachother, I use 3 analog sensors connected ro my arduino and when i run my vi the results seems not correct, and the signals form is too.but in another hand when i use just one single sensor it works great. is there any advice on how to fix this problem?
Thanks for any help
(4,418 Views)
Connect the unused inputs to ground.
hrh212
(4,050 Views)
Is there other solution because it doesn't work for me, i did connect other pins to ground but it doesn't work the problem persist, labview still gives wrong data with a signal plotted not correct, it's seems that the values drops down and the execution is delayed when a add a second sensor to my arduino.
thanks for help hrh212.
Appreciate other suggestions.
(4,050 Views)
In Arduino Pullup resistors are not connected.. we need to connect the pull pup resistors to make the floating voltage to constant Zero if the pin is unwired.
Sathish Kumar A
Certified LabVIEW Architect (CLA)
(2,913 Views)
