LabVIEW Interface for Arduino Discussions
Problem with ultrasonic sensor HC-SR04 .. Please HELP!
I have a problem with the ultrasonic ( HC-SR04) .. it's my first time to use Labview
first i'm using labview 2015 version and Arduino IDE version 1.6.9
The problem is i tried to test the sensor and make sure that i can calculate the distance using the interface between labview and arduino ,so i used a simple program shown below using the sensor uploaded in this topic ..
https://forums.ni.com/t5/LabVIEW-Interface-for-Arduino/LIFA-Ultrasonic-Distance-Sensor/ta-p/3514004
But the indicator does not show anything !!
knowing that i installed the VISA program and arduino board works well and i uploaded the LIFA Base code before using it and i tried simple program to blink a led and it works  !!
Here screenshots : first labview program and its output
and the same program using arduino IDE to calculate the distance
and sorry for my bad language
thanks,
Labview program:
The Sensor Works well !!!
(10,324 Views)
Accepted by Samics
I highly recommend using LINX with this fixed VI.  If you have further issues with this method, please create a thread on the LINX forum.
(10,253 Views)
ok i will try thank you so much 🙂
(10,244 Views)
