LabVIEW Interface for Arduino Blog
Community Browser
Labels
Re: I can't deploy Lifa- base code to arduino!
I'm from Brazil, and I need your help!
I started to work with interface Labview/ arduino mega2560, and I can't  deploy Lifa- base code to arduino!
my software version is:
LabVIEW 2011;
id-arduino 1.5.6-r2;
Could someone help me?
thank you...
Comments
barddya
This is a common issue.
Check your visa port (make sure coect one is selected on your PC and Arduino
make sure you select the correct model (Uno, Mega ..etc)
Use 9600 for your baud rate (are all other parameters correctly set?)
If the Lifa-base in correct folder will all other files?
If you still have issues, give more details. what kind of erreor do you see
Matheus-UNIFEI
I believe this part is right!
When compiling the program the following error appears:
C:\Program Files (x86)\Arduino\libraries\RobotIRremote\src\IRremoteTools.cpp:5: error: 'TKD2' was not declared in this scope
thank you very much barddya!!
giuiuyoyp
i dont have the lifa base file in order to do the compilation
what am i suppose to do
barddya
gluluyoyp.
Go to this link
https://www.labviewhacker.com/doku.php?id=lvh_blog:user:sammy_k:2014_04_16_linx
Read, Install and use LINX instead of all you would to use arduio and Labview
LINX is the latest and the greatest and the only platform that currently has supported
Barddya
syarydayah
how to solve the problem?i get the same command
