Installation and Operation instructions for the
AdaFruitMotorShieldStepperDriver.VI
Introduction
This VI does not use the LIFA firmware. Instead it
uses Labview's serial interface capability to communicate
with a sketch running on an Arduino Uno. This VI is not
compatible with the Arduino Leonardo because a version of
the AfMotor library is not available for the Arduino Leonardo.
Although the Adafruit Motor shield maybe used with up to 4 DC
motors this VI does not support the motor shield's DC motor
capability.
Note the following procedure assumes you have installed the
Adafruit Motor Shield on your Arduino Uno, connected one step
motor to Motor Ports M1 and M2 and connected the other step
motor to Motor Ports M3 and M4. If not see the Adafruit Motor
Shield Documentation for additional information.
Installation Instructions
1. Use 7zip to unpack "AdafruitMotorShieldStrepperDriver.7z".
If you don't have a copy of 7zip you can get a copy here.
2. Move the AfMotor and TextFinder libraries to your Arduuino
IDE "libraries" folder.
3. Move the AdafruitStepperDriver sketch folder to your Arduino
sketch folder.
4. Move the AdafruitMotorShieldStepperDriver, X Running Sum and
Y Running sum VIs to your your collection of Labview examples folder.
5. Compile and download the AdafruitStepperDriver sketch to your
Adruino Uno.
Operating Instructions
6. Open the AdafruitMotorShieldAStepperDriver.VI.
7. On the front panel and set the serial Port to your Arduino
Uno's COM port
8. Run the VI.
9 Set the "X Steps Setpoint" and "Y Steps Setpoint" to the
number of steps you want the X and Y step motors to move.
The step motor connected to M! and M2 is the X step motor.
and the step motor connected to M3 and M4 is the Y step motor.
10. Click on the "Send" button to send the setpoint data to
the Arduino Uno and to start the motors stepping.
11. As required repeat steps 9 and 10.
12. A negative "Steps Setpoint" will cause a step motor to
rotate in the opposite direction of a positive "Steps
Setpoint"
13. The "X Step Position" and "Y Step Position" indicators
show how many steps the step motors have moved from their
starting position.
14. To get back to the starting position multiply the "X Step
Position" and "Y Step Position" values by minus 1 and enter
these values into the their respective "X Steps Setpoint" and
"Y Steps Setpoint" controls and then click on "Send".
15. To quit click on the "Stop" button.
Additional Comments.
The step motor speed was set to 10 RPM during the testing
phase. If required you can set it to a higher value.
Adafruit says they ave run the small step motors they sell
at 250 RPM. Change the step motor speed by replacing "10"
in these two lines of code
motor1.setSpeed(10); // 10 rpm
motor2.setSpeed(10); // 10 rpm
in the AdafruitStepperDriver sketch to an appropriate value.
Four different stepping modes are available with the Adafruit
Motor shield. They are SINGLE, DOUBLE. INTERLEAVE or MICROSTEP.
Adafruit documentation says " "Single" means single-coil
activation, "double" means 2 coils are activated at once (for
higher torque) and "interleave" means that it alternates between
single and double to get twice the resolution (but of course its
half the speed). "Microstepping" is a method where the coils are
PWM'd to create smooth motion between steps."
To change the stepping mode replace "SINGLE in these two lines of
motor1.step(steps1, dir1, SINGLE);
motor2.step(steps2, dir2, SINGLE);
in the AdafruitStepperDriver sketch to one of the other 3 modes.
Capitalization is required.
Note if you want to reload the LIFA firmware on the Arduino Uno
you used with the Adafruit Motor Shield you will need to
temporarily nove the AfMotor library out of the Arduino
"libraries" folder. The LIFA firmware will not compile when the
Afmotor library is in the Arduino "libraries" folder.
The following components were used while testing this software.
Arduino Uno.
Assembled Motor Shield Expansion Board. Source:
<http://www.ebay.com/itm/Motor-Drive-Shield-Expansion-Board-L293D
-For-Arduino-Duemilanove-Mega-UNO-/290700252856?pt=LH_DefaultDomain
_0&hash=item43af15d6b8>
12 volt DC power supply, Jameco # 2082134 ADAPTER,WALL,REG SW,
12VDC 2AMP
Stepper Motors See:
Did you ever made it work with V2.0 of the motor shield DocMaly?
I am also trying to use this with Arduino Uno R3 and Adafruit v2.3. However it doesn't work. I am using only one step motor (ports M3 and M4). Can I use the same arduino sketch and Labview code when I am using only one stepper motor.
Yes you can use one stepper as well. I did try one and two steppers and it works fine in both cases.
Will the drivers work with the Adafruit Motor/Stepper/Servo Shield for Arduino v2 Kit - v2.3?
