Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
I would like the vi metrics to record the time spent on programming individual vi's, broken down into seperate operations: cleaning block diagram, writing code, drawing icons etc. The function should be able to stop recording when someone is not working with the vi. Ideally time spent on other programs while the project or vi is opened should not be recorded.
