User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
Problem:
in many cases after wiring in the loop , we will go for the shift register to store variable. but in case of changing the loop tunnel to shift register left side tunnel required to connect manually.if not it creates the another tunnel in the loop.
solution:
in the loop , if the left and right tunnel variable are same , LabVIEW automatically replace tunnels with the shift registers.
