PJM_Labview
"CTRL + Double Click" on a VI in project windows should open the VI Block Diagram.
Status: New
Have VI in the project windows behave like SubVI so when you CTRL + Double Click on one the SubVI FP and BD opens (and the BD is frontmost).
vipm.io | jki.net
9 Comments
JackDunaway
Trusted Enthusiast
This is not a "handy feature," this is a REQUIREMENT for more advanced UI apps. If a VI is inserted into a SubPanel, you cannot open the BD of the inserted VI! If you double click that VI in the project, it simply "blinks" the SubPanel to tell you "Here it is!" You must drag an instance of the VI onto a blank VI, then CTRL+Double Click on the subVI to open up the BD.
LabBEAN
Why does this not have more Kudos?
NI, please check here and here when weighing the necessity of getting to the diagram when Ctrl-E is unavailable.
*thanks*
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
fabric
This concept is so useful that I would like to see an explicit "Open Diagram" option in the right-click menu too:
I'm sure this has been mentioned elsewhere, but since this is the idea that's about to get over the line...
PaulLotz
I, too, have often wanted this!
wireman
I don't know how many times I have really wished this feature was in LabVIEW! I find myself having to open a new blank VI and drop the Main.vi, which is already running with its own menu (so I can't ctrl-E or use the Show Block Diagram), so I can get the Main.vi block diagram open.
Please, please add this!
Hooovahh
Proven Zealot
Good idea, I can already open the block diagram of a running VI by holding CTRL when double clicking the subVI (with auto-tool off).  Having it be consistent with other ways of opening a VI is a good idea.
Florent_A
NI Employee (retired)
Hi All,
I made a project provider that is not exactly working like you want but might help :
https://decibel.ni.com/content/docs/DOC-39245
Flo
Flo
scwimbush
Add my vote for this. Like wireman, I often want to view the block diagram of a running VI (with custom menu) that I foolishly forgot to open the block diagram of before running. The only way I knew of until today is to kill the running VI, open the block diagram and then restart the VI again, which is often more trouble than it's worth. (I now find myself pre-emptively opening the block diagrams of VIs I'm about to run "just in case".) I also expected to find this option in a right-click menu as fabric.
Now at least I know (from the discussion here) that "all" I have to do is create a new VI, drop the running VI onto its block diagram and ctrl-double-click (hidden command) the VI symbol to get the block diagram to open!
Petru_Tarabuta
+1. I have just posted a related idea: Block-Diagram-Only VIs (VIs without a Front Panel)
