the decorations in the front panel have properties, these properties you can to modify in execution time, but the order off these decorations is created automaticaly, and the newer decoration object, it's the first, and other existing decorations your order number is changed automaticaly.
Proposed solutions
- the automatic order number should be generated, in the same order to are created the decorations, in the same way of controls
- create a new function to modifying the order number, the same way to modify the tab order of the controls.
