ouadji
object locked and colors
Status: Declined
                When an object is locked, we can not change, neither his position, nor its size.
                                           but we can still change its color. This is not logical.
                                                           i disagree with this behavior
              When an object is locked, we should not be allowed to change its color(s).
                    (sorry for my broken english, i try to do my best)
10 Comments
AristosQueue (NI)
NI Employee (retired)
I filed this as a bug report as CAR #342471. The behavior goes back at least to LV 7.1, probably longer.
Mads
As this choice is in a menu related to positioning and order I've always thought of the lock as a position lock, not a change lock.
ouadji
Trusted Enthusiast
the position is locked, the size is locked ... and color should also be locked.
When an object is locked, it can not be half locked.
Mr.Mike
I believe locked only applies to size and position, too.
-- Mike
ouadji
Trusted Enthusiast
only for position and size ?
yes, obviously, since for now we can still change the color. Smiley Wink
Darin.K
Trusted Enthusiast
Echoing Mads comment, let me be precise in my statement: Based on the context of the menu, locking *should* only apply to position and size. If you really do not want color changes consider a strict type def.
GregR
This is either not a bug or it is a much bigger bug than just the color. Here are a few more things you can do to interact with a control that is locked.
  • Operate a button
  • Edit the text in a numeric or string
  • Operate the inc/dec arrows of a numeric
  • Change the selected item of a listbox
  • Change the control's label
  • Change a button's bool text
  • Modify the items in a listbox
  • Change the range of a slider
  • Change the plot style of a graph through the plot legend
  • Add controls to a tab of a tab control
The list goes on and on. Locking as currently defined only covers 3 operations: selection, context menu (right click) and resize. We can decide to change the definition of the feature but until then I'm closing the CAR that AQ created. If you think we should change the feature, feel free to Kudo the idea.
donkdonk
"only covers 3 operations: selection, context menu (right click) and resize"
For me, this is ok. I usually use locking just for not accidently moving it (especially for tab controls or pictures where you want to drop control/indictors on top).
I still would like to be able to change everything else.
AristosQueue (NI)
After GregR talked to me yesterday... I agree it would be bad to change this behavior.
MaryH
Status changed to: Declined
the Locked option is only for position and size
