User | Kudos |
21 | |
18 | |
11 | |
5 | |
3 |
As everybody knows there are two ways for generating an empty string constant in the block diagram: Using the "empty-string"-constant or creating a genereal string constant with no content.
Both ways have advantages and disadvantages:
- The "empty-string"-constant shows much better that the string is empty but it can't be used e.g. in arrays.
- The string-constant can always be used, it is easily generated by right-klick to a string terminal and selecting "create -> constant". Furthermore its value can be changed to somthing non-empty if required. Disadvantage: It's hard to see if the constant contains nothing or just a blank sign.
My suggestion: LabVIEW shall show a string constant which contains an empty string always with the symbol that is currently used for the "empty string"-constant. This is also valid if the empty string is within an array or cluster. If this behaviour is not wanted in a particular case, there shall be the conext-menu-option "show symbol for empty string" which could be deactivated.
For changing the value of such a new string constant, the symbol shall change to a classic string constant if the user moves the mouse (with selected text-editing-tool) over it.
Similar behaviour is also suggested for general-path- / empty-path-constants.
Remark: I'm working with LV2015SP1
