I can't say I have a need for this, but it should be fairly simple to write a JKI RCF plugin to do this. You basically just need to create a new enum control and push the values into it using the Strings[] property.
We use a tool like this almost every day. But remember, by nature, that enum cannot be in memory, so this VI is only a design-time tool, not a run-time tool.
Message Edited by JackDunaway on 11-19-2009 09:17 AM
@davekorpi Enums are type-safe selectors whose value is visible on the diagram in case structures and probes. Rings are pure display objects that return a raw integer and support string localization. Enums protect you from cross-wiring and ensure that your code breaks if new cases are added. Rings are used for user interfaces where you may need to dynamically populate with text from various sources. In general, rings should be used exclusively for UI front panels and enums should be used exclusively for subVI connector panes.
