User | Kudos |
4 | |
3 | |
2 | |
1 | |
1 |
Build array is one of the most VIs used with shift register.
It is always a bit annoying from UI perspective only to see this curly line which would be much better if connector of appended array is moved below as proposed in the picture above.
Duplicate of https://forums.ni.com/t5/LabVIEW-Idea-Exchange/LV2010-Merge-Errors-Improvement/idi-p/1219856
