What I propose is to have functionality built into the XNet API that is similar to the DAQmx API. I'd want a separate subpalette where functions like Start, and Stop logging can be invoked which will log the raw data from an XNet interface into a TDMS file. Maybe even some other functions like forcing a new file, or forcing a new file after the current file is so old, or of a certain file size. On buses that are heavily loaded, reading every frame, and then logging it can be use a non-trivial amount of resources, and having this built into the API would likely be more efficient.
XNet already has a standard for how to read and write raw frames into a TDMS file that is compatible with DIAdem, and has several shipping examples with LabVIEW to log into this format.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
