| User | Kudos |
| 11 | |
| 10 | |
| 7 | |
| 5 | |
| 4 |
Customer received this error after trying to send J1939 frames on XNET Bus Monitor, once user select J1939 database , there is no option to transmit frames , not sure why XNET Bus monitor does not have that tab, xnet does it support it, using a labview code is possible but xnet bus monitor is something very practical for Customer to use before going to code.
Also when this type of error occurs need to have better description as J1939 and CAN FD not supported in XNET Bus Monitor.
