I sometimes feel difficult to see the value of
a wire while editing the VI. When "Retain Wire Values" is turned ON, I
need to put a probe on that wire to see last executed value. Applying
probe on every other wire while coding will result in lot of probes and
also it will increase the coding time.
Having a way to
view the wire value on Mouse Hover in edit time will be really useful. What I feel
is, the value can be displayed as a tooltip or a dialog box similar to
context help window which will disappear when mouse pointer is removed
from the wire. 🙂
When the programs finishes the values are lost. But if you pause it, like you showed with the breakpoint, most of the simpler data (numbers, strings and booleans, file path, etc.) is shown in a Tip Strip, just like you said! For more complex data nothing is shown, like file references, and others wires some information is given, like in arrays that it's size is shown.
I like your Idea! Many times I've needed it. It may also be good to add Data Type: e.g. Labview (Str) or 235 (U16). Sometimes the control is in the case 2 while the wire you are sampling is in case 4. I know the type is in the HELP screen, but this addition would be for convenience sake.
Any user can click on the number part of the Kudos button to see who all has Kudoed that Idea. Many of us have subscribed to different boards so that we can actively keep up with the interesting conversations, and when subscribe you do that you receive a separate email for every comment as soon as it's posted. Just a friendly reminder to post replies that add to the value of the conversation on the Ideas! Helps increase the Signal-to-Noise ratio of the comments, and keeps those actively subscribed to the boards from getting excited over nothing. Not trying to be a Grumpy Old Man...
I am not really an expert G programmer, but my thoughts are as follows :
a) Personally, I would only be interested in knowing wire values while debugging at the run-time(which is currently available through 'Retain wire values').
b) Performance hit : The values of wires would be constantly appearing(even when the user does not need them) when the user is just moving his mouse over the code - this would have hit on the edit time performance - though I am not sure how significant. Also, it may be little irritating for the user to see the values appearing/disappearing when he is just moving the mouse over the code.
I think we may like to show the wire values by having 'hovering the mouse over' along with a keyboard click, something like, Ctrl + 'Hover the mouse over' - this would mean 'On demand display'.
