User | Kudos |
6 | |
3 | |
3 | |
2 | |
2 |
As shown in below image we can see that, if I index numeric array and wire it with any of the node from numeric function it gives un-aligned wire whereas as same process if I use Boolean function at output of index it gives well aligned wire.
So due to this numeric function node wire to index out terminal makes our code with full of wire bends which is not as per NI LabVIEW coding standards also.
So here, I want to draw attention for NI, to do some correction to specific numeric function nodes so we can make neat and clean code in LabVIEW.
