Petru_Tarabuta
When replacing front panel objects user should be given option to preserve attributes or not
Status: New
Background
This idea is derived from the following idea: Front panel controls and indicators should be genuine after being replaced with control or indicator... . Please read that thread for background.
Problem
There are three ways to replace front panel controls and indicators:
1. Right-click the control or indicator, select Replace, then select the select the object to replace with.
2. Select the control or indicator, press Ctrl + Space to bring up QuickDrop, search for the object to replace with, then press Ctrl + P.
3. Select a control or indicator and press Ctrl + X. The control will disappear from the front panel. Select another control or indicator. Press Ctrl + V. The second control is replaced by the first control.
The first two methods preserve some of the look and feel of the original object. For example, when replacing a Modern-style string control with a classic-style string control, the end result is a control that looks like a mixture between the two styles. This may or may not be desired behaviour.
The third method does not preserve any of the attributes of the object that was replaced. The end result is a control that looks exactly like the control that was selected when Ctrl + X was pressed.
Both behaviours can be desireable in different situations, and it's good that there are ways to achieve both. However, the third method is not easily discoverable.
Proposed solution
A more intuitive and discoverable solution could be: After right clicking an object, selecting Replace, and selecting the object to replace with, a two button dialogue message could popup. The message could ask something like "Preserve attributes?" The buttons' Boolean text could be "Yes" and "No".
Ideally the same popup would appear when using the QuickDrop Ctrl + Space, Ctrl + P method.
This would:
1. Enable the user to select either to preserve attributes or not, depending on their intention at that particular moment. (the same user may prefer either behaviour at different times)
2. Increase awareness that two behaviours are available
