I think it would be nice if LabVIEW was smart enough to know that when I drop a For Loop around scalar inputs it doesn't auto-index output tunnels - but rather uses Shift Registers - for matching inputs and outputs.
The common use case for this is with the Error input/output - it annoys me how it becomes an Array output.
As it is already wired, inline and not broken, dropping a For Loop around it should not break my code!
Reference or Class inputs are other use case too - I want to pass the same thing around not create an Array.
Shift registers are better than non-auto-indexed tunnels (other option) as they protect the inputs on zero iterations.
This would remove one step required for most use cases, speeding up my development experience.
Certified LabVIEW Architect * LabVIEW Champion
Implemented in LabVIEW 2014
