This is similar to the idea about moving items in the connector pane and is an extension of it for any input or output on the block diagram -
Often, you connect a wire to a wrong input or output. Today, fixing it requires wiring to the new location and manually deleting the old piece of wire. The only exception is two-input functions with both inputs already wired, where you have a keyboard shortcut for swapping the wires.
A much more natural and general method would be this - if you use the wiring tool on a wire source or sink and then on another, the wires should be swapped (or if there's only one wire, it should be moved).
In this example I wired the 7 into the wrong input and I want to move it one input down, so I:
1. Click the top input. This "grabs" the wire, so to speak.
2. Click the bottom input. This moves the grabbed wire to that input.
Message Edited by Support on 10-22-2009 01:25 PM
___________________
Try to take over the world!
