The I2C Digital Waveform Reference Library is a good choice to test the I2C Interface with timings that
are outside the specification. This is important for the developers to invesigate what happens when a
new designed chip get a not specified I2C signal.
Citation from the readme file:
Supported Targets
This component is compatible with the following LabVIEW 8.6 (or later) targets
The API library and installed examples may be compatible with other LabVIEW targets, but they have not been tested.
Unfortunately the Library needs the LabView 8.6 Run-Time Library installed and it is not certain that it work with Windows 7 and
LabVIEW 2012. (I tested it and it works with this combination ) It would be nice if the Library can be updated and tested for
Windows 7 and LabVIEW 2012, to prevent that developers are uncertain if this "old" Library still works.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
