User | Kudos |
18 | |
5 | |
4 | |
4 | |
4 |
Recently I've been trying out Labview's Unit Test Framework Toolkit and I like it enough that I'm proposing we purchase it for our core developers. However, there are a few things that I think would improve the UI and make it much more friendly.
1. Why does the VI Under Test tree control collapse every time I switch to a different test case? The input and output list don't change for the different test cases, so if I have the tree expanded and I'm switching test cases it probably means I want to look at those tree nodes. This is by far the single most annoying UI behavior I've come across in a while.
2. How about the ability to add a notes field to each test case that so I could comment why that test case exists.
3. If in addition to the notes field there were also a title field for each test case, then all the test cases could be listed in the Category pane as subnodes under the Test Cases node. It would make it much easier to find the test case I'm looking for. (And dare I ask for the ability to reorder the test cases as well?)
